Ever Find Anything Interesting In Your Philco?
Hello:
Did you ever find anything interesting hiding in the cabinet when you took apart that old Philco you were working on? I bet you did. I'm sure everyone will want to hear about it.
William
Not in a Philco, but in a 1927 American Bosch Cruiser, I found a homebrewed amplifier with a good 01A.
[Image: http://www.citlink.net/~jsaxe/Amp.jpg]
This cute little tube tester was in there, too.
[Image: http://www.citlink.net/~jsaxe/DayRad.JPG]
Not a bad for $6.95
John
73 de KC2HET
See my small collection at:
http://www.citlink.net/~jsaxe/Radios
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 415 online users. [Complete List]
» 2 Member(s) | 413 Guest(s)
