32 volt Philco
I am looking for a 32 volt Philco or other brand in working condition.
How many were made and what models were they?.
I am more familiar with the Delco R32xx series that were popular as well.
I have a 32 volt Delco system, and like to display working 32 volt lights and other appliances.
Thank you
Mike
The only one I am aware of is the model 32, which is based on the Philco 89 circuit. I understand that they are quite rare. I found one on eBay, but it is not for sale. Its restoration is documented on my web site:
http://mcclellans.com/Philco32B.htm
Dave
Correction to my last post - I was referring to PHILCO 32 volt sets that I am aware of. I have the following 32 volt sets in my collection, and many more exist:
Airline 62-138 (Wells-Gardner Series 6B)
Silvertone 1925
Universal Battery Company 6132
Universal Battery Company 7232
Erla (Sentinel) 67L(134BL)
Karola (Brame Mfg Co Mnps)
Coronado (by Wells-Gardner & Co.) Series 7T5
Setchell Carlson 437
Delco 3201
Others:
Midland B6B
Knight 5646K(?)
Coronado (Gamble Scogmo) 36L
Crosley 159
Coronado (by Gamble-Scogmo Inc. Ch 36-L) 36L8600
Dave is correct on the Philco model 32. It was made in different cabinets for several years until about 1935. These used vibrator supplies for high voltage. Philco made a model for the 1936 model line, their last 32 volt set model 642 which like some of the other sets made used low voltage, 32 volts for B+ with type 48 tubes in push pull. I have a Lafayette 32 volt set like the Philco 642 with type 48's. The power output is only about a third of a watt but the set performs amazingly well with only 32 volts on the plates of the tubes.
Fred R
Do either of you have a working one for sale?
Again, I have the 32 volt system, and actually use Edison batteries to store the electricity.....
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 415 online users. [Complete List]
» 2 Member(s) | 413 Guest(s)
