PHILCO 38-15 Mod notes?
Thx all
So putting a 78 tube in and I will replace the 1M's and the 250K.
Can always put it back. If I have any issue's. I want to see the difference with the schematic and this Mod any way.
I will let the Phorum know.
Just want to confirm what I am reading.
Thx
Take a look at this schematic:
http://www.nostalgiaair.org/PagesByModel...013233.pdf
It appears that the AVC circuit of this 38-10 model is wired the same way as what you now have (with 6Q7G instead of the 75, but same function). You can see the two 1 Meg resistors connected to the diode plate, with the mica cap connected to the IF coil.
The 250K triode plate load resistor should really not make any difference in operation.
Check the operation of the AVC, because if you remove the 1 Meg resistors, you may disable the AVC function.
Let us know what you find.
Yes
I was just going to rewire per schematic.
I see that whom ever did this mod might of had some problems in the circuit.
So went to this to clean up his AVC.
I have ordered all the resistors.
I will just replace the ones there first see what I get on the radio.
Thank you Very much Mondial this does very clearly show what was done to the 38-15 I have.
Any issues I'll be back
Brad
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
There are currently 760 online users. [Complete List]
» 1 Member(s) | 759 Guest(s)
