37-116 lamp socket
Hey guys,
question to those who know the part number or where to order.
The 37-116 I have has 5 sockets for dial lighting and 4 of those are the "flattened" type mounted on two sides of the dial assy frame, that is they have the "horn" part of the socket going around the lamp "flattened" and not round.
The 5th one is the round type (probably goes on top of the assy) and it is the one that is damaged.
Q: what is the part number, and where do I get it? I cannot see it listed in Rider.
Or maybe someone has it - I would buy from you then.
I think this is the same type right over the dial.
http://www.ebay.com/itm/PHILCO-RADIO-MOD...41759c88c8
Mike.
How is it damaged? If you can still put a bulb in it, Ron's light rebuilding trick works great, costs almost nothing, and lasts a long time.
http://www.philcoradio.com/tech/lamps.htm
John
Las Vegas, NV USA
It is damaged in such a way that the spring is not there anymore.
But I was buying bunch of stuff from Oldradioparts and the socket (after I found the chassis online to show it to the guy - did not know the type) happened to be 78 cents....guess what I did. Icon_smile
PS. Came with a bulb too!
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
