1963 Admiral record player
[attachment=2308][attachment=2309]I am working on an Admiral record changer. It works great except for the mechanism that is used to select for the record size. I found that a part is broken. See pictures. The thin rod that sticks out is busted off. I think it is suppose to bend around and hook into the top of the size selector. I was wondering if by chance anyone has one that they could send me a picture of this part. Maybe I could make one. Or if someone had the part to sale.
Thanks Bob
I forgot to put the model number. It is RC7B1S-24H
I've got a very similar setup on my daughter's 1954 Admiral. I'll see if I can dig it out and get you some pics real soon.
Thanks Eric. I won't need the pictures because I found a unit on Ebay that was being sold for parts and it is just like the one I got. What is missing is a spring arrangement. So it looks like I'll have some extra parts, so some time in the future I might be able to help someone else with a part.
Bob
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1161 online users. [Complete List]
» 2 Member(s) | 1159 Guest(s)
