Hello, and a question
Hi everyuone. I aquired a large Philco console yesterday, but i cannot find a schematic, Its a 41-269. I've asked at other place, and looked over many pictures to find one close to it, but with no luck, the tube lineup is odd, i think someone just plugged tubes in it, no rectifier, 2 differnt kinds of out puts. does have 2-#41's which i'm geussing is what is supposed to be the output tubes. Don't have much more information than that. I'm hoping some one here might reconize it, and would be able to give me a tube lineup thats correct.
Thanks
Jeremy
Hi Jeremy
Sorry, Philco did not produce a 41-269. Maybe it is a 41-296? Can you provide photos to help identify it?
Well it could be a 41-296, I might have misread the tag?..... Its a very large console radio, no phonoo player, Eight tubes, 41 P-P output. the other tubes seem to be whatever some one plugged in to take up space.its a 9 tube set. Has a very large speaker, over a foot in diameter. has a large rounded grill like and old car. Unfortunatley i put it in storge, as i have too much at home right now, and i didn't take a picture. THanks for the help
Jeremy
Hi Jeremy
Well, I looked...Model 41-296 uses the same chassis as Model 41-285 (nine tubes). It is pictured and described here:
http://www.philcoradio.com/gallery/1941b.htm#j
The tube lineup is: (2) XXL, (2) 7B7, (1) 7A6, (1) 7C6, (2) 41, (1) 84.
Would an output transformer if weak, cause the problems I am seeing with lower B+ voltage? murfmurf — 01:22 PM
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - GaryGarySP — 10:21 PM
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
