Antenna help on a 41-265
Hi everyone! I'm new to the site, and also new to antique radios. We inherited a Philco 41-265 that was my great-grandparents and have had it electronically restored, and I restored the cabinet. I live in a small town in central IL and would like to be able to pick up WSM 650 AM out of Nashville, TN. When we first got the radio back from being restored, when it was just sitting in the kitchen to try it out, we could get it on a clear night. Now that we have re-arranged the living room for the radio to sit in a corner, we no longer can get it. I would like to run an antenna to it, and can get to the attic to run a long-wire antenna, but thought I'd get some input first. There are 4 antenna screws on the radio, with wires currently being connected to 2,3, and 4. What screws would I hook the antenna up to, and do I need a ground wire? It does bring in local stations, but between stations there is a lot of static and a constant loud hum. Thanks in advance, and any help will be greatly appreciated!
Hi Travis and welcome to the Phorum.
Well you will be surprised how well it will pick up stations with an antenna connected to it. A single wire will work OK general rule is as long and as high as you can get it. A sling shot can be a handy tool to get it high up into the trees if you have some. A good ground will help too. It will probably cut do on some of the noise you are hearing.As far as connections I'd pick the 1st screw on the left but it doesn't hurt to try others.
Philco model 40-100
Arran, Thank you so much for your assistance and the link to the fleabay listing! They say a picture is worth a thousan...mhamby — 01:43 PM
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
There are currently 527 online users. [Complete List]
» 4 Member(s) | 523 Guest(s)
AvatarAvatarAvatarAvatar
