Philco 42-380 Presets
I would like to set the 5 preset buttons on a Philco 42-380 console. I see on the back of the chassis there are two rows of 5 trimmers. Is the top row which have each trimmer labeled 1-5 the trimmers that adjust the preset buttons? The lower row of 5 trimmers are labeled 540, 600, 650, 850, 900. Thanks, Charlie
I believe you adjust the lower 1-5 coils to the station you want that's in the range of that particular coil, and use the trimmer on the top of that coil to fine adjust the station. Or it could be the other way around.
If the stations are strong enough you can tune the coils/trimmers without to much trouble, but if there is a weak station you might have to use an signal generator to tune in on the stations frequency.
-Keith
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
There are currently 1319 online users. [Complete List]
» 1 Member(s) | 1318 Guest(s)
