Hello need help with my 1951 730L
Just joined and wanted to say hello. Wondered if anyone can tell me if this is right. Just got a Canadian 730L ,
seems to be the same as the 51-1730. I removed the unit from the cabinet and found a tube underneath
that seems to be wired into the record player, it it wired properly, was this added to replace another tube
that had gone bad or is it normal. Also notice it is a little burnt.
Welcome to the Phorum!
I'm thinking that is a capacitor, and it needs replacing. And all the other capacitors will need replacing as well.You will need to find a schematic for your set. I'm sure others will chime in here.
Gene
Welcome to the Phorum. I see you have a schematic and that's the first place to start checking things. I've not worked on this model before but that black "tube" looks to be an electrolytic capacitor. From what you said it seems it was wired in but hanging loose under the radio chassis. That leads me to suspect it was added later to replace one of the original electrolytic caps that had failed. The indentation on the cardboard was where it was clamped onto a chassis at some time in its life. I'd replace all the paper and electrolytic caps as they appear in the schematic.
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
Neat looking set, definitely Euro- style. I am guessing that this is solidstate due to the vent holes (or lack thereof,...MrFixr55 — 09:32 PM
Haha, thank you sir! I’ve been eyeballing a 47-1230 console for sale over north of Bentonville, Arkansas for a while. Pr...jrblasde — 09:18 PM
There are currently 659 online users. [Complete List]
» 2 Member(s) | 657 Guest(s)
