40-201 Antenna Shield Repair
I had originally thought about removing the antenna electrostatic shield for my 40-201 model and had materials rounded up to dip it into a 5 gallon container of water to make the paper come apart. I looked at the piece and realized that it was stitched together with thread along the edge where the shield came together. I decided upon a far easier solution. It will not be very pretty, but is far easier. I had already strengthened the inside of the shield using paper grocery sack material and Elmer's glue. It had turned out to be too brittle to slide back over the oval wooden ends.
With the stitching thread removed, I could easily open it just enough to slide over the oval wooden ends without damaging the shield any more than I already had. I slid it over the oval forms and carefully stapled it to the wooden oval pieces one end at a time. Then I laid a bead of Elmer's glue between the ends that overlap and took a series of rubber bands to hold the ends in proper overlap so the glue would set properly. Here is a picture of the assembly curing on my bench.
Later I willl put a new label on it to complete the repair. This way, it will be functional with less work and still retain the original elements as manufactured.
Joe
As a follow-up, I tried the antenna on the radio this afternoon and it does improve reception by removing excess noise on many AM stations that I tuned in. I also have a GE Superadio II which is a pretty decent receiver. It cannot match the performance of the Philco 40-201 tuned to some of the same stations. It speaks pretty well of a 73 year old design approach. I brought the SW high band antenna in from the cabinet and had to replace one lead and a missing terminal lug on one lead. With this loop attached I have good signals on the highest SW band. The electrostatic shield plus orientation by rotation brings in the best signal on AM broadcast and the police band low end where the upper end of the AM broadcast band is covered on this radio.
Joe
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1036 online users. [Complete List]
» 1 Member(s) | 1035 Guest(s)
