Philco D-10A Cartridge
The Philco 46-1209 that I am working on for a friend has the D-10A magnetic cartridge. The cartridge works and has an original style needke in it so it is OK. has anyone found a source for these needles or are they still unobtainium? I need to re-flock the turntable and get a new idler but I don't want to spend that money if I can't provide my friend with a player that he can't get spare needles for.
What about the possiblity of converting it to the D-10 crystal cartridge which I understand is still available? I know the output will be higner but that can probably handled with some mods. I was thinking more of mounting the carttridge.
Any other suggestions?
Wayne
You have to get real lucky to find a needle for the D10A, I found one on ebay once, only once. it is virtually uno btainable, there are others still trying to find one. I hear you can switch to the D10 tone arm with the crystal cartridge instead.
Keep checking ebay it's your best bet I was luck enough to get one.
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
There are currently 1313 online users. [Complete List]
» 1 Member(s) | 1312 Guest(s)
