philco 41-230 parts list
Hi Guy's,
Have a Philco 41-230 I want to re-cap, but Nostalgia has no parts list for this chassis.
They have schematics, but I cannot read the values on their schematics.
I want to do the electrolitics first, and it looks like someone has been in there before and put in a double cap with I believe is a double 8 mfd 450 volt cap.
Can't be sure if that is what should be there as I cannot read the blurred schematics from NA.
There is also a large cap which was replaced which is number 40 on the schemtics.
Numbers are not legible on the cap, so I have to rely on the parts list, which I do not have access to.
Any help from anyone would be appreciated.
Thanks
murf
[Image: http://i1161.photobucket.com/albums/q509...1-2301.jpg]
Hi Murf:
I have a nice clear schematic with values if you still need.
Gregb
Input cap is 12mfd output is 4mfd@450v
murf, there's a parts list in the service bulletin you can find here: http://www.audiophool.com/Philco.html
Thanks Bob,
Unfortunately I can't view it with the windows software that I have.
Don't want to purchase what they want to sell you to be able to view the djvue(whatever) format they use.
murf[/font]
[font=Tahoma]
Here ya go, a pdf version of it.
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
There are currently 1313 online users. [Complete List]
» 1 Member(s) | 1312 Guest(s)
