The radio cloth
Hi,
It may be a long shot, but still worth asking.Original cloth is in the very good condition, just weathered. Glued to the plywood removable frame. looks new from the back side. Is there any way to have it removed and flip over? I was thinking to use some steam, perhaps.Have nothing to loose, as I restore the cabinet and will need new look anyway, so if it is damaged- be it, will get the new one, but it is not the same. Any ideas? Thanks.
You can try heating the glued edges with a blow dryer. It may loosen the glue.
If you can get the glue off , that is great but I have not been able to get it all off , ,but as you say ,if it does not work put a new cloth on.
It might be worth a try, depending on how close a pattern you can find if it does not work.
Since then I was able to remove the old fabric twice (table top sets) by gently blotting the edges with a lacquer thinner and pulling them away. The speaker side is usually not weathered and very close in pattern to the face side. I believe it could be reused.
Yes, and if there is enough length and width, the cloth may be moved a bit to displace faded areas. Some cloths were affixed with "water glass" which is soluble in, guess what? A cardboard equivalent replacement substrate can be made with patience. Even a tear or two can be fixed by a sharp eye (certainly no longer mine,) and some thread.
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
There are currently 642 online users. [Complete List]
» 1 Member(s) | 641 Guest(s)
