Caps In Series
If you put two .04ufd caps in series you'll get a .02ufd cap. But what happens to their 630 volt rating?
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
It becomes 1260V rating. In theory and more or less in practice.
uh, I didn't think the voltage rating changed.
Yes it did.
Hey Peper,
Long time no post!
Good to hear from you.
Morzh,
You're right.  Oops, I was thinking parallel, not series. Icon_redface
(12-08-2015, 10:39 PM)Art Hoch Wrote:  Morzh,
 Parallel you double up on the capacity, but the voltage stays the same. I can't remember the physics about why you can connect caps in series to double the voltage rating, but I'm glad that you can, and it works, and have taken advantage of this principle many times. I'm sure that Mike can explain the why, but then again I could just look it up.
The physics is simple: two caps of equal capacitance in series will get charge to exact half the charge each hence the voltage being Q/C, it will therefore be 1/2 voltage across each.
Obviously for exact voltage rating doubling you need exact same two caps.
The half charge is explained by the fact that the same current goes through both caps and so both charge equally.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
There are currently 596 online users. [Complete List]
» 1 Member(s) | 595 Guest(s)
