Help needed for identification
I've found yesterday a small radio (Canadian model -15$) and I'm trying to find the schematic, but the parts number do not fit with the schematics I have (Beitman). The line resistor is around 300ohms (110+190) and the part #33-3372. The tubes: 35z3, 35a5, 7a8. 7b7. 7c6; I will post some pictures, if somebody has any info's.
The heaters of the tubes seems to be ok (I don't have a tube tester). I'll try to restore this small radio (re-cap, clean, etc..). It's my first Philco. The cabinet it's all wood. Should I sand-it and paint-it with polyurethane base paint?
Some other information's: chassis type 26, stamp on the chassis: P 4233; written inside the box with pain: xxx.12.39 (the xxx characters are under the paper with the lamps location and I can't remove the paper without destroying-it).
https://www.dropbox.com/s/l2j1f5elfssomy...4.JPG?dl=0
https://www.dropbox.com/s/yjqnevbarhq9kz...5.JPG?dl=0
https://www.dropbox.com/s/zrga1k5juirxok...7.JPG?dl=0
https://www.dropbox.com/s/6c1qqyeifnmy41...9.JPG?dl=0
Welcome to the Phorum!!! Icon_wave
I believe the Canadian model 26 is similar to the US TP-12. See Ron's chart of Canadian models.
NO polyurethane please. The finish used on these radios was lacquer and is actually easier to work with and repair than polyurethane. You'll find lots of threads in the cabinet restoration section on use of lacquer toners and clears.
Here's the TP-12 schematic..
Lots of friendly folks here to answer questions.
Hi again,
I've restored the radio, changed the caps and fire up. It's working, but I get a lot of noise. The hum is very minimal for a AA5 radio. What should I do to reduce the noise for this small Philco?
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 1139 online users. [Complete List]
» 1 Member(s) | 1138 Guest(s)
