BIG SCOTT CONSOLE CABINET RESTORE
Threads: 147
City: Dallas, TX
Threads: 147
City: Dallas, TX
Threads: 22
City: Waxahachie, TX
That will look great when you're done with it Fred!
Crist
I love the Scott Tasman cabinet - I think it is one of Scott's best looking sets. I probably should have held on to the AW 23 and Tasman that I had. Oh well, maybe after retirement, I'll pursue another....
Anyway, Fred, I am sure you will do your usual fine work with this one!
Threads: 147
City: Dallas, TX
Threads: 147
City: Dallas, TX
Threads: 105
City: Calgary, AB, CA
Very nice Fred. I always like to see your work. I have not used the Mohawk grain filler.
I have used the kind that you spread on with flat spreader and wait until it is almost dry, then use the burlap.
is Mohawk similar in application?
Dan in Calgary.
Living in Calgary Alberta
Threads: 147
City: Dallas, TX
Hello Dan, I quess Mohawk is about the same in regards to application . I wipe it off with fresh burlap before it dries hard like wax a car. I let it haze over then wipe it smooth, then later sand it off with 240 after it has dried overnight, clean and smooth out the crevices as show in pictures, that also before it gets hard.
Threads: 310
City: Kings Park NY
It looks terrible!
I will surely take it off your hands
You will have to show me how you did the veneer. Veneer on large areas scares me....
Me
AC: 4 DC: 1
Threads: 147
City: Dallas, TX
Threads: 69
City: Kansas city, MO.
Threads: 147
City: Dallas, TX
Threads: 22
You are truly a craftsmen!
Crist
Threads: 214
City: Seattle
State, Province, Country: WA
Stunning! Thank you for all of the photos.
Threads: 114
City: Sneedville, TN
My Philco 37-116 Restore
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM |
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM |
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM |
Hello Ed,
yes, I like letting projects run for few days to make sure they don't start acting up .
Sincerely Richardradiorich — 01:03 PM |
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM |
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM |
Refinishing Ideas
Hi Doppelganger,
After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM |
Philco model #20
Hi Rick,
One other thing regarding volume on this set. Make sure that the tube shield is in place. this is that la...MrFixr55 — 08:22 AM |
Philco model #20
Hi Rick,
The volume control on the Model 20 has 2 sections and does 2 seperate things:
One part of the control, ...MrFixr55 — 10:30 PM |
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM |
There are currently 956 online users. [Complete List] » 1 Member(s) | 955 Guest(s)
