70 speaker
How do you know it is a 70 speaker?
I am buying some speakers and he doesnt remember which are which.
They need re-coning though. Do you want one Fredrick if it needs re-coning?
Me
(02-25-2016, 08:10 AM)OldRestorer Wrote:  How do you know it is a 70 speaker?
Me
Sure Kirk, the 70 speaker will have 3 wires coming off transformer to plug it instead of 4. Four wires are for the 90 with push pull other than that I think they are the same. Also I do have enough speaker grill cloth that you asked about, the gold color chain link pattern. PM me
Doesn't the 20 also have the 3 wires... How do I tell it from the 20?
Message me the total for the grill cloth if you are sure you want to sell it.
Me
The 20 speaker has four wires also has a nut on the back of the field frame.
M R Radios   C M Tubes
(02-25-2016, 11:26 AM)OldRestorer Wrote:  Doesn't the 20 also have the 3 wires... How do I tell it from the 20?
Me
OK Icon_eek I WILL
Well
Nut is not the tell-tell; some of 90 speakers look same as 70 but electrically are like 20 for pushpull version and like 70 in SE.
The 4 wires mean pushpull (20 and some 90s), 3 mean SE, 70 and some other 90s.
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
There are currently 1025 online users. [Complete List]
» 3 Member(s) | 1022 Guest(s)
