Model 650 Cap 77, 10mfd, Polarity Question
Hello:
I've nearly finisher recapping a model 650. Ecap number 77 is dual. The 10mfd section is connected to the transformer center tap and ground. I'm wondering about the polarity. Should the positive end of the 10mfd cap connect to the center tap and the negative end connect to ground?
The center tap being the most negative point the chassis is more positive. I would connect the + to chassis.
The positive terminal should connect to chassis ground, and the negative to the center tap.
The center tap is the most negative voltage  point in the circuit, so the negative terminal of the cap connects there.
Yes this is one of those questions asked about few hundred times here.
The connection is counter-intuitive, as people are accustomed to seeing GND being the most negative point and so caps' minusses going to it.
In this case which is present in many radios, the centertap is the most negative point in the whole of the schematic; everything else relative to it is positive.
Hence the capacitor's minus goes to the centertap, and the plus goes to the Ground (chassis).
Thanks for your help and expertise.
Dave
That's the negative supply that offers negative voltages to grids (mostly) throughout the radio. It's a common circuit in most radios, primarily the better ones.  You don't need a high voltage cap in these circuits and 50 volts is very safe. As in the other posts, this cap has a positive connected to ground.
Pete AI2V
There are currently 1541 online users. [Complete List]
» 1 Member(s) | 1540 Guest(s)
