Threads: 573
The second radio I started today.
It is a brown backelite 38-12.
I bought it for a very good price of $40 and the shipping was reasonable. The lady wrapped it in very few plastic store bags plus put some pieces of bubble wrap in between the tubes, despite my advice, but somehow the radio was lucky and arrived totally undamaged. Or so I think.
Here are the pics:
Front. I have already bought the dial cover from Mark Palmquist
Back
Dial/speaker
Chassis' top. Dusty, aren't we.
Bottom of the chassis. The full opposite of the top, no pun intended.
Threads: 573
Typical....on the speaker the xfmr primary's open. I might have the transformer though.....
Field is good and this is what's important.
Threads: 270
You may want to consider put a thin piece of clear plastic between the dial and pointer.
Common with the pointer tearing up the foil on the dial.
Threads: 573
All tubes are very strong.
Threads: 424
City: Boston
That is a great suggestion Terry, I learned the hardway and now must endure a very plain looking Radio Daze repro on one of my Philcos.
Threads: 573
I will see if it is close enough, will do that. Thanks.
Threads: 573
I resumed Sunday after Kutztown.
Removed the old output transformer, had to drill out the rivets.
Rebuilt both caps yesterday, recapped everything, three resistors had to go.
Opened and cleaned the volume pot.
Today replaced the output xfmr, having riveted it to the speaker.
Connected everything, powered it up.
Works fine, receives stations across the dial.
Need to align obviously.
Need to remove and wash the tuning cap, very dirty.
Then the alignment.
Then gluing the dial cover, cleaning the cabinet, maybe learning how to polish it a bit, assemble the radio.
Done for today.
Threads: 573
Removed the tuning cap. It's a pain but affer 620 with its switch and all it was almost a breeze.
Now it is soaking. The gromnets solidified and crumbled. I could've left it since it was working fine but there is a lot of dirt in it and around and it feels wrong. Plus it has the string. Simple but.....I hate strings.
Threads: 573
Well the ekectrical part's done.
Put all back in, aligned it.
Realized the volume pot is acting up. Opened it again, cleaned with alcohol, then some Deoxit plus taking the shaft out and bending the wiper just a tad. Then it worked nicely.
Now I am trying to manufacture the cloth holding board out of some Foam Core board.
Tomorrow will see.
Threads: 573
Threads: 276
City: Wilsonville
State, Province, Country: OR
Threads: 573
Threads: 11
City: Bellmawr, NJ
Threads: 573
You're right. I will.
Rogers Majestic R-646
Today I finished inspecting all the parts. The result is not very pleasing.
The first positive news:
1) The power tr...Vlad95 — 11:40 PM |
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM |
Well, maybe - maybe not :lol: It's been an interesting project so far! Something so simple, yet so cranky. The 1st one ...TV MAN — 05:12 PM |
Haven't thought of Burgess batteres in a while
https://www.radionostalgia.ca/lib/Images/battery/us/burgess1D.jpgi
...Vlad95 — 03:50 PM |
Measure the voltages first, just in case.morzh — 02:19 PM |
Haven't thought of Burgess batteries in a while Mr. Fixer. Boston Edison always used Burgess in their Bright Star yellow...Paul Philco322 — 02:17 PM |
Thanks Sam. I'll let you know. I can probably scare some up from the local radio club.klondike98 — 02:07 PM |
Philco 89 Code 123 Osc Coil
Hello,
I thought I would post my findings on my bad oscillator tickler coil. There were 27 turns on the outer coil b...dconant — 12:38 PM |
Thanks Morzh. So it appears I did wire it incorrectly and I have to switch the wires between pins 2 and 4.bobclausen — 09:24 AM |
No, it's not a problem, just during certain condition it could show up.
Yes, an internal tube short could do that too.
...morzh — 09:13 AM |
