can a 41-280 escutcheon go into a 42-380 cabinet?
Threads: 1
City: Albany, California
Have a battered 41-280, someone parked it in a shed for 30 years and the sides warped. Would like to salvage the faceplate, buttons, glass, etc. but perhaps have them put into a 42-380 body that's in better shape. Is this even remotely feasible? And if so, how would I clean up the buttons?
Thanks!
Hi Debra,
Yes - if you remove everything from the 41-280 cabinet, it should all fit in the 42-380 cabinet.
You can't use a 42-380 escutcheon with a 41-280 chassis and vice versa, though, because the 41-280 has 8 pushbuttons and the 42-380 has 9.
Bob has alrady given you some good advice on cleaning the knobs and pushbuttons here.
Threads: 1
(04-26-2016, 06:07 AM)Ron Ramirez Wrote: Hi Debra,
Thanks for the info on switching out chassis, and also Bob's info on the buttons. I've worked on the buttons and they improved, but do show considerable wear. Will have to get "new" ones from http://www.renovatedradios.com/parts.html. Do you know if there is more than one type for the 1941 consoles (41-280 and/or 42-380), that is, long, short, etc.???
Also re the band below the buttons, is that copper? I saw the advice about not using Brasso on it....
Thanks!!
~Debra
Threads: 12
City: Nashville, TN
(04-27-2016, 05:44 PM)debra Wrote: Also re the band below the buttons, is that copper? I saw the advice about not using Brasso on it....
Thanks!!
~Debra
Hi Debra. The metal strip is brass I believe. If you use Brasso, i will remove a clear coating and get down to the actual metal. That also may remove the lettering. ( I forget if the lettering is flush with the strip, or if it is lower.) In other words filled with a paint. If your strip is very badly tarnished, no amount of polishing that clear surface will get rid of it.
Also if the lettering is not indented below the surface, you'd have to apply decals or lettering to replace it.
That's the worse case scenario. A lot of work to remove the old clear, polish the metal back bright, and then letter it, then coat with a clear to prevent tarnishing. But, it can be done...
Good luck!
Threads: 54
(04-29-2016, 10:45 PM)gary rabbitt Wrote: (04-27-2016, 05:44 PM)debra Wrote: Also re the band below the buttons, is that copper? I saw the advice about not using Brasso on it....
Thanks!!
~Debra
Good luck!
Gary;
I'm pretty sure that the lettering is embossed in the brass strip in some way, and then filled with paint, if it was not the lettering would have rubbed off on most of them a long time ago.
Philco model 40-100
Arran, I restored 2 Canadian battery-crank telephones for a friend a while ago, a Northern Electric (Canadian version of...MrFixr55 — 08:04 AM |
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM |
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM |
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM |
Philco model 40-100
Marion;
By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM |
hello jrblasde ,
your radio sounds great well done !!
I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM |
Philco model 40-100
Arran,
I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM |
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM |
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM |
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM |
There are currently 569 online users. [Complete List] » 3 Member(s) | 566 Guest(s)
