Philco 20 Baby Grand Movie Star!
Threads: 11
City: Christchurch, New Zealand
That chassis looks really tidy - and I like the gold personally - I think it tells the story of the radio... Me personally, I'd keep it that way because it does go with the history you know (and the history you can only imagine) the radio has. Just be glad its not mustard yellow
Its really nice, and the story with it is just awesome... congratulations on becoming the latest caretaker for this great piece of history.
There are no personal problems that can't be overcome with the liberal application of high explosives
Threads: 40
City: Sanger, CA
Thanks Steve. I realize that this is a fairly common model Philco, but being an old 1930's movie fan since I was a teenager, this radio has dual interest for me. I'm hoping that someone out there will eventually have some info on the charity auction this one was part of. So far searching hasn't found anything.
Like you, I believe we are just the caretakers of the old things in our charge. It will retain the finish that's on it while I own it. An upgrade to a better used speaker cloth, or appropriately aged new cloth, would be my only contribution.
(This post was last modified: 05-06-2016, 11:06 AM by SteveG.
Edit Reason: Added text
City: Lexington, KY
That's a pretty unique piece with some very interesting history, I'm glad you are going preserve it as found. I wonder if a gentle application of GoJo might remove some of the black on the cabinet?
Threads: 40
City: Sanger, CA
John,
Being a big fan of "the GoJo Treatment", I considered what that would do to the finish. It looks like they brushed on the gold and some areas have aged differently than others, most likely due to a second coat in those areas. I feel that I might change the remaining finish for the worse, if I try any cleaning with more than a moist cloth. The gold has darkened with the past 85+ years and looks great in person. I cleaned some tiny white paint dots from a long ago ceiling paint job in a room where this thing sat. Other than a better speaker cloth, I think I'll leave it as it sits.
Threads: 40
City: Sanger, CA
It also looks like there may have been a dark primer coat under the gold. I think that's what's producing the dark areas on the front and the sides of the cabinet.
(This post was last modified: 05-06-2016, 08:09 PM by SteveG.
Edit Reason: text
City: Lexington, KY
Well, since you can see the cabinet in person you're a much better judge of what is going on. In-any-case, it is a very interesting radio. A quick search shows that Mary Brian lived to be 96!
SteveG - I would like to add my congratulations on an amazing find!
Threads: 40
City: Sanger, CA
Thanks Ron. Hoping you can find some speaker cloth at KT for me!
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits.
For example, this schematics solution is used...Vlad95 — 01:43 PM |
No, you are wrong, because you did not know the details.
Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM |
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM |
Thanks RodB for the help.
But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM |
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM |
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM |
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM |
Today I finished inspecting all the parts. The result is not very pleasing.
The first positive news:
1) The power tr...Vlad95 — 11:40 PM |
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM |
Well, maybe - maybe not :lol: It's been an interesting project so far! Something so simple, yet so cranky. The 1st one ...TV MAN — 05:12 PM |
