Philco 39-6 dial cover and grill cloth.
Threads: 573
Made the new frame ang glued the cloth.
Question: I want to staple it to the front.
What kind of stapler do I need and where could I buy it?
City: Lexington, KY
This is a wood cabinet right? If so you want something like the Arrow T50 staple gun:
http://www.arrowfastener.com/ccrz__Produ...owfastener
Available at HD and Lowes make sure the staples you buy are not long enough to pierce through to the outside of the cabinet. Arrow is still made in the USA and I have one or two still going strong after hanging many rolls of insulation in a previous house years ago.
Threads: 69
City: Kansas city, MO.
+ one on making sure your staples are not too long. I did that once to a little table radio I had spent much time restoring. The staples punched through the front in two places. I was able to refill the holes but felt dumb for not checking the length first.
+2. The same thing happened to me on a wood 38-14 I had carefully refinished.
Threads: 573
Thanks guys.
Yes I specifically am !ooking for shallow staples as I do have a regular Stanley gun (which is Arrow) with regular staples and it would not occur to me to use it as they are too long, and this is the reason I asked.
I thought the staple gun that uses smaller staples is a smaller gun in the first place.
Sorta like using an elephant gun to shoot a sparrow
I guess I will go to Lowes and take my gun with me to compare to T50 and see if this one also can use the same staples.
City: Lexington, KY
(This post was last modified: 05-22-2016, 11:29 AM by Eliot Ness.)
Threads: 573
Ha-ha
Anyways, the Lowes proved to be a fiasco, the shortest staples there is 1/4" which is what I have already.
The Hobby Lobby is closed today.
In my desperation I am thinking of a possibility of taking quarter-inch ones and vrinding them down to 1/8 of an inch.
Threads: 573
Guys what size of staples do you use?
Seems like 1/4 is the smallest around but I think it is too large?
City: Lexington, KY
I don't think you can get smaller than 1/4" unless you go to a fine wire upholstery stapler, and all that I've seen are air powered. If you think 1/4" is too long put a small piece or two of cardboard between the backer board and the stapler.
I think John Goller uses a regular office stapler with the base removed.... that seems like a pretty thin staple to me, but it works for him.
Threads: 573
Are you using 1/4" for small cabinets?
Office staples look too thin, I am not sure if they can pierce plywood.
City: Lexington, KY
I have, but my backing board might be thicker than what you are using. I think I used a framing mat from Michael's and I may have used 2 thicknesses.
Threads: 573
Aha...I am fhinking to maybe pad the staples with pieces of the same material I use for the frame but then it might create push back agsinst the speaker...or not if it is outside the speaker's rim. Have to look.
But... what do you think of grinding the staples? Should be fairly easy.
City: Lexington, KY
Grinding them down might be an option, but be sure to wear eye protection!
Threads: 573
I will
Also has to be held by pliers or it can end up in your finger
Threads: 573
I have just successfully stapled the frame to the front.
I used my staplegun, my 1/4" staples and the leftover pieces of the frame material as padding.
Plus a little glue to keep it from vibrating.
Mr. Fixr
Compared to you I am sooo green behibd the ears...I have about 40 or so sets.morzh — 07:12 PM |
48-482 rear panel help
Many thanks to all for the responses!
No plastic button "covers" on my radio.
Ron, thanks for the chapter on...keithchip — 05:53 PM |
I am back to working on this radio and managed to get a couple of radio stations to come in. But can someone help me to ...osanders0311 — 01:58 PM |
Hi Kettlechip and welcom to the Phorum.
The back panel question is interesting. I have quite a few radios that use pow...MrFixr55 — 08:24 AM |
Not too much at all! :lol: Sounds like you’re just dabbling into the hobby!jrblasde — 07:56 AM |
Hi Joseph,
Fortunately, Ms. Fixr does not read my computer, or she would warn you against coming to me for sanity ch...MrFixr55 — 07:27 AM |
There's a picture of one of the plastic covers in the following thread:
I bought a full set of them in 2012 or so fro...klondike98 — 11:15 PM |
Good sanity check! You are correct—the first (as in, the most counterclockwise) position is for the push button presets....jrblasde — 11:05 PM |
Hi Joseph,
First, verify that your band selector is in the correct position for what you want to do. I believe tha...MrFixr55 — 10:59 PM |
Got my replacement signal generator in the mail today! I was able to finish alignment of the IF section. I’ve got some t...jrblasde — 09:58 PM |
There are currently 1163 online users. [Complete List] » 2 Member(s) | 1161 Guest(s)
