Philco Bathtub Block 3903AH ?
Can't find a listing on this one.
Assume it is a .01 Block
It was changed at some point according to Philco to 3903 SG . Nothing on it either.
Bob T
Yes is a 0.01 uF cap as seen below:
[Image: https://dl.dropboxusercontent.com/u/5462...903-AH.jpg]
3903-SG would be a lower melting point wax than the 3903-0SG  (the O was for higher temp wax) but should have the same configuration.  See Ron's post of Bakelite Condenser Data or Chuck's Bakelite Block Values page.
(05-29-2016, 06:25 PM)klondike98 Wrote:  Yes is a 0.01 uF cap as seen below:
Thank you Sir. Only 6 more to go on the 16
Bob T
If you have not seen it, here is a nice thread on restuffing these caps.
http://philcoradio.com/phorum/showthread.php?tid=9107
(05-30-2016, 08:04 AM)klondike98 Wrote:  If you have not seen it, here is a nice thread on restuffing these caps.
I use to use my Commercial Heat Gun to remove the Blocks. No More
Before Doing this Procedure check and know what your Block Contains. Blocks containing Resistors DO NOT DRILL
Now I have used the method by cutting the wires on top of Block where the inside parts are soldered. Then drilling a small size drill dead center of Tar , yes drill right on through the Caps inside.
Once you have drilled to the Bakelite, stop.  Then I use a fine thread sheet rock screw 1 1/2" long
Thread it in slowly into your drilled hole with a Phillips screwdriver. You will be amazed as you seen the entire Tar block Caps and all slowly come out.
Has not failed me yet.
Been using it on the 14 Block 16B I am working on.
Just remember to FIRST cut the wires on top where the internal parts are soldered to.
This is not my idea, I believe I saw this method over on Chuck's Site.
Bob T
Philco 38-7 Speaker
The put-put is not like the speaker problem.morzh — 08:29 PM
Mission Bell Model 19A Car Radio
Hello everyone,  As mentioned in my last post I was going to see if the vibrator / rectifier section could be persuaded...Antipodal — 08:21 PM
Philco 60 Squealing
Wondering if I did it backwards. If a coil was wound backwards, the oscillator would not work at all. Old school...Chas — 07:23 PM
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
Philco 42-390, code 121 speaker
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
Philco 60 Squealing
I'm pretty sure I now have the litz wire soldered. This did not make any difference. Back in April I rewound the seconda...dconant — 06:25 PM
Philco 38-7 Speaker
Just to make sure, you chose either 4 ohm into 5K or into 10K? (blk-org or blk-grn)morzh — 06:23 PM
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
