Zenith 7-S-240 Eye tube question
Have you rechecked the 1M (R15) resistor in the eye socket between pins 2 & 4.   Also pull the eye tube out and make sure there are no shorts between pins, except for 2 -4.   I'd also trace out and verify the 6T5 socket is going everywhere it is supposed to.
Other than the eye tube not closing properly, how does the radio perform?  Does it seem to pick up normal stations like it should at a normal volume?  Do you have to turn the volume down quite a bit going from a weak to a strong station?  Something is keeping your AVC voltage too low.
I hate to say it, but I'd double check any capacitors, resistors, or anything else you may have changed against the schematic for wiring errors (it happens to the best of us).
Hopefully Terry will take a break from his 42-854 and offer some more insights.
Just for grins try hooking a 9V battery to the grid, + to the chassis - to the grid. If all is well with the tube (6E5) should close it up.
Traced out all 6 pins and they go where they are supposed to.
also re-verified Resistors 5, 6, 7, 14, 15 and C7
Radio receives stations good (what I'm used to) have about 15-20' of antenna Vol is good across the stations
Ran all my eye tubes through the tube tester Knight 600A all were good also did the 6T5 again and it is better than I remembered so I'm going to use it
Hooked up a 9v with the + to chassis and the - to the 3 pin of the 6T5 it closes the eye about 15% from full open and drops the station vol by 30% also voltage goes from -2.8 to -9.2v with the battery
going to do some more tracing and verifying on what I have done
Nothing else to do on a rainy day down here!....:-)
(06-05-2016, 12:13 PM)Eric Wrote:  ....Hooked up a 9v with the + to chassis and the - to the 3 pin of the 6T5 it closes the eye about 15% from full open and drops the station vol by 30%  also voltage goes from -2.8 to -9.2v with the battery....
Try it with the 6E5.  The 6T5, like the 6U5 takes ~ -22 volts to close.  The 6E5 only takes ~ -8 volts. Instead of hooking it directly to pin 3, hook it to a point under the chassis that goes to pin 3.
Still something is amiss, you should have much more AVC than what you're seeing.
Hooked it to the end of R6 made no dif, Still looking for something I or somebody else might have misconnected.
Ok I have a couple of questions C-21 10mf ceramic and R-16 1K ohms I can't seem to find them? in the print they are located in the upper left corner and in the parts list center bottom. Are they even in the chassis?
Looks like R16 is part of the#2 coil assembly, so it might be inside that can.  C21 is part of the antenna coil assembly.  It might be a good idea to ohm out the first two coil assemblies.
    Can't find C-21 or R-16 Doubt they are in there here are some pictures of the cans and Chassis. Never heard of a 10 mfd ceramic,
Chassis
Would be a 10mmfd or 10uufd not 10mfd.
Agreed it's a misprint as the parts list does say 10 mfd, still nothing there
Not inside the Tube of the coil ?????
(06-08-2016, 11:35 AM)Kenneth F. Besso Jr. Wrote:  Not inside the Tube of the coil ?????
Found  C-21 not inside the coil just underneath the chassis they had replaced it with a .02mf and I followed and replaced the paper cap with a new .02mf. traced it out and found it replaced it with a 15mmf. rechecked the alignment and checked the eye still no change.
Philco model 40-100
That was part pf what began my interest in tube battery radios, the variety of circuit designs, especially by Grimes-Pho...Arran — 02:37 PM
Phill; I had a look at my Riders "Specialized" car radio books yesterday, I don't have one that covers Stud...Arran — 01:50 PM
Philco Model 249 made in England
Thanks for the information MrFixr55.   It's tube amplification and not solid state. TOMfklown — 11:27 AM
Well, I’ll be! I learned something.jrblasde — 11:03 AM
Yes, Garrard was well-regarded for its standalones.morzh — 10:48 AM
Quite the interesting stories, sir! Somewhat reminds me of my first job out of school (not that I worked in a similar fi...jrblasde — 09:33 AM
Philco model 40-100
Arran, I restored 2 Canadian battery-crank telephones for a friend a while ago, a Northern Electric (Canadian version of...MrFixr55 — 08:04 AM
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
There are currently 1067 online users. [Complete List]
» 2 Member(s) | 1065 Guest(s)
