Can You Wash Photofinish???
Hi all....that's my question...can you wash photofinish??? I had four or five radios at an antique store that suffered a fire. None are fire or heat damaged but all are soot covered. Three are Philco radios; a 42-340, a 42 PT-3, and a 49-500. Two have photofinish, the 42 PT-3 is covered with it. Can it be cleaned and how??? My thanks in advance....
I have used GoJo or Goop hand cleaner on cabinets with a photofinish and then wiped with a damp sponge without problems.
Interesting questing. I think it depends on the condition of the photofinish. Badly worn or spotted finish maybe a bit problematic to clean up. If it's in good shape I would  use some water on a cloth to clean, wouldn't rub really vigorously.If you like bubbles a bit of baby shampoo will give you a little more cleaning action but is still pretty mild.
I have a few Philcote sets that where spotted badly but was able the use some acrylic paints to touch up these areas. Afterwords gave it a few lite coats of lacquer to blend the touch ups. Turned out well.
Hmm, it is hard to say. We had a fire and I know that soot is one of the hardest things to get cleaned off. Usually the finish comes off with it,it is baked on too. Try the gojo that was suggested. Probably your best bet.
When we had a house fire, the insurance clean up crew washed down the house quite well using TSP (trisodiumphosphate) mixed in water.  Mix some in warm water, dip, then wring out a soft rag, and try it on a small area before attacking the entire radio.  If they are as bad as you seem to indicate that they are, what have you got to lose? Take care, Gary
Philco model 40-100
Arran, I restored 2 Canadian battery-crank telephones for a friend a while ago, a Northern Electric (Canadian version of...MrFixr55 — 08:04 AM
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
There are currently 559 online users. [Complete List]
» 3 Member(s) | 556 Guest(s)
