Ron's 2016 Cabinet Work Part III: 38-624T
Here we go...
The weather prognosticators are calling for at least one more week of warm weather here, so I'm tackling a 37-610T second version 38-624T cabinet.
[Image: http://www.philcoradio.com/images/phorum/37610_001.jpg]
I had purchased this as an empty cabinet. Later, I found - and bought - a very rough 37-640B tombstone in order to obtain the chassis, speaker, knobs and escutcheon for use in this 38-624T cabinet. Kirk has the 37-640B cabinet now; he said he wanted to practice on replicating photofinishes, and that cabinet will be an ideal candidate for that.
Anyway...
This cabinet had a few flaws here and there.
Left side:
[Image: http://www.philcoradio.com/images/phorum/37610_002.jpg]
There was a deep groove in the bottom trim which I filled with wood filler. A small chunk of the back corner of the trim was missing; this, too, was filled with wood filler as you see in the photo above.
Front:
[Image: http://www.philcoradio.com/images/phorum/37610_004.jpg]
Some deep faults in the upper right corner of the front panel were filled with wood filler. Later, I will attempt to touch up the light areas with some Medium Walnut toner - but only after the cabinet has been stripped, sealed, and grain filled.
Right side:
[Image: http://www.philcoradio.com/images/phorum/37610_003.jpg]
There was a large depression where you see the piece of veneer. The cabinet had been hit with something, pushing the wood in. I thought about what to do about this before deciding to glue on a piece of veneer, and then try to sand it until the veneer patch more or less blended in.
more to come...
Edit: For reference, here are the other two cabinets I worked on this year.
Part I: Bozak E-300 Speakers
Part II: Philco Tropic 42-788
After sanding...and sanding...and sanding...until my thumb was bleeding...
[Image: http://www.philcoradio.com/images/phorum/37610_005.jpg]
Not perfect, but it looks better than it did with the damaged spot.
more to come...
I looked inside the cabinet...
...and discovered that I was wrong about what this cabinet had been originally.
The two identifying stickers are both badly damaged, but there is enough of the model number sticker to indicate that its background was...green, not blue.
Ah ha! A battery radio. So it had to have been a 38-623T or 38-624T originally.
A lot of the tube layout sticker is likewise gone, but there was enough to indicate a vibrator power supply and a few of the 1 volt battery tubes.
Battery tubes, vibrator supply - it was originally a 38-624T. I've changed the title of this thread accordingly.
Hey, Jeff (PhilcoPhan1936) - didn't your cabinet come with a 38-623 or 38-624 chassis?
After stripping:
[Image: http://www.philcoradio.com/images/phorum/37610_006.jpg]
Not bad...but stripping the finish in combination with the bright sunshine revealed...more flaws!
Uh-oh! Spaghettios!
[Image: http://www.philcoradio.com/images/phorum/37610_007.jpg]
[Image: http://www.philcoradio.com/images/phorum/37610_008.jpg]
The gouges in top can be easily dealt with by using walnut color Timber Mate...but what about the veneer damage on the front panel?
No matter what I do, the repair will show...
...so I took the easy way out and applied walnut Timber Mate to the front panel as well.
Some more natural wood filler was applied to the bottom edges of the bottom front trim where there were more minor gouges and such.
Now, I'm waiting for all of the stuff to dry so I can sand it all down and see what I have to work with.
It is getting curiouser and curiouser!
How it looks now:
[Image: http://www.philcoradio.com/images/phorum/37610_009.jpg]
The Timber Mate where the missing veneer was on the right edge of the front panel:
[Image: http://www.philcoradio.com/images/phorum/37610_010.jpg]
I think I might get away with carefully drawing in some faux grain with a black ink pen.
The top:
[Image: http://www.philcoradio.com/images/phorum/37610_011.jpg]
And the bottom edge of the front molding:
[Image: http://www.philcoradio.com/images/phorum/37610_012.jpg]
I added a little more Timber Mate here and there in places where it still needed it.
Tomorrow...hopefully...spray sealer followed by grain filler! Icon_think
Well...
...let's spray sanding sealer at 10 pm!
[Image: http://www.philcoradio.com/images/phorum/37610_013.jpg]
[Image: http://www.philcoradio.com/images/phorum/37610_014.jpg]
[Image: http://www.philcoradio.com/images/phorum/37610_015.jpg]
[Image: http://www.philcoradio.com/images/phorum/37610_016.jpg]
It was exceptionally...unusually...warm at 10:30 pm tonight. I opened the garage door to let the house garage air out before taking these pictures. After being somewhat cool the past several evenings, it is really warm tonight!
The first coats of lacquer always highlight a cabinet's flaws, and this cabinet has several. However, I think I'll take the flaws over tossing this cabinet in the burn pile at Kutztown. Icon_eek
So...tomorrow...grain filler! Icon_biggrin
Man's gotta know when stop spayin' Icon_lol
Ron did you spray sanding sealer or clear lacquer? If sanding sealer, do you sand before using grain filler?
Coming along nicely.
Another day...more cabinet work...
Here's the cabinet after application of grain filler on the front panel.
[Image: http://www.philcoradio.com/images/phorum/37610_017.jpg]
Letting the stuff dry to a dull haze, I then scraped it off at an angle, then rubbed it in with burlap. Sorry, Kirk, but I have lots and lots of burlap that needs to be used up...and it worked well for me three years ago.
How it looks now:
[Image: http://www.philcoradio.com/images/phorum/37610_018.jpg]
It definitely needs more grain filler along the top part of the front panel as well as the left side and some of the grillebars. The rest seems to be OK when looking at it in bright sunshine.
This wood really has large, open pores! Much larger pores than I think I have seen before.
KCMike, to answer your questions:
I used Deft lacquer sanding sealer. Three coats which is more than I usually apply (I normally apply two), but this cabinet is so dried out and in such poor shape that I thought three would be beneficial.
And I sand after applying grain filler. This removes any remaining filler residue from the surface of the veneer as well as levels the surface in preparation for toner.
I shall continue after lunch, working on the top and sides. My goal is to have it ready to sand and apply medium walnut toner tomorrow after work.
Grain filling is complete!
[Image: http://www.philcoradio.com/images/phorum/37610_019.jpg]
It looks really dark now, but it won't look as dark once it is sanded. The grain filler will have to dry overnight. And as I must return to work tomorrow...that means it has until tomorrow evening to get dry. Plenty of time.
If all goes well...sanding and Medium Walnut toner tomorrow evening!
Flaws???
Hahahahahahahahahahahaha..
Spackle this...
HOOOOOLLLLLLYYYYYYY COOOOOWWWWW!!! Icon_eek
Start patching veneer...else save it for the Kutztown burn pile...
Or better yet...put it outside your door in lieu of a pumpkin for tomorrow night! Icon_thumbup
Icon_lol
I will offer it up to the veneer donor pile since there is no chassis anyway...
Lookin good Ron...
Me
**Edit.. Maybe... It would only take one piece of veneer to fix the face and the rest is solid.... UGh....
Okay!
After work and supper, I began to sand off the grain filler residue.
I sanded...
and sanded...
went through three pieces of sandpaper as they kept getting clogged up with grain filler residue...
(yes, I did scrape off excess until the paper totally lost its effectiveness, at which poinit I switched to another piece of sandpaper, and carried on.)
Finally, the cabinet was ready for Medium Walnut toner!
I applied two coats. Here's how it looked right after the second coat:
[Image: http://www.philcoradio.com/images/phorum/37610_020.jpg]
[Image: http://www.philcoradio.com/images/phorum/37610_021.jpg]
A little while later, out of the house garage and back on my workbench...
[Image: http://www.philcoradio.com/images/phorum/37610_022.jpg]
[Image: http://www.philcoradio.com/images/phorum/37610_023.jpg]
A bit darker than I wanted, but the wood was already dark and that affected the final color. (See post #7 above for a comparison.) In person, I think the color is quite pleasing. It will look even better once I get the Extra Dark Walnut on the bottom trim.
The flaws on the front panel do not show in the photos. It looks like some brat whacked it multiple times, and unfortunately that will always show. But as I said before, I consider it a rescue...beats putting it on the burn pile at Kutztown, eh!
On a good news note, the grain on the front appears to be 100% filled! Icon_thumbup I didn't get the grain completely filled on top as there are some areas where I can see some partially-filled pores. But I think after the coats of clear, sanding, more coats of clear, etc., that any remaining pores will be mostly filled and it will look fine (save for the flaws, that is).
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
