Philco 46-1209
#31
I use the yellow ones. The dip cap can be the wrong shape to restuff into the old cardboard tube from the old cap. The down side to using the non dip cap is if you happen to brush your soldering iron you can kiss it good bye. The dips have an epoxy coating.
Now I think I've got it!
I usually determine which cap architecture makes the most sense for each capacitor that will be replaced. I too order mostly the yellow ones with axial leads unless it makes more sense to use a cap with radial leads, such as restuffing bakelite blocks.
I don't order kits. I only order exactly what I need from Just Radios.
#33
Thanks, Some parts arrived today.. My caps for them AC line and some resistors I needed.. So back to the replacement of caps and resistors..Then on to the volume control and tone control .. They seemed not to be working correctly so I need to check again
Skip...
#34
Ok, Continue with the Recap.. Found this radio uses some .006 Caps..
See Picture..
[Image: http://i292.photobucket.com/albums/mm38/...hbarav.jpg]
C201 and C200 Maybe more not sure.. I do not have anything close. Closet value I have is a .0047 Will that work? Or do I need to get one closer?
Skip...
#35
ur fine
I thought so.. But wanted to make sure.. Thanks again Terry..
Skip...
There are currently 1547 online users. [Complete List]
» 1 Member(s) | 1546 Guest(s)
