Giid leak voltage on Sears 101.557-1 chassis
Threads: 13
City: Rockville, MD
Hi all. Been working on this for a while off and on. Re-capped, re-resistored, aligned(at least I think it's right). Now I get one strong station at 1600kc, but the oscillator seems to drop out as I dial toward the lower end of the dial. Grid leak voltage on the LO drops to almost nothing at that point. Why would the tuning cap cause this voltage to drop? All suggestions gratefully accepted. Thanks, Ed
Threads: 270
Hi Ed,
So your under winx's tower???
Check voltage on pin's 3 and 4 of the mixer tube if you have the 140v or so replace the 6J8. This is assuming that set has been serviced, tube sockets and tuning cap have been cleaned, and check for bent plates. Also check C-6 for proper tracking at the low end of the bc band, could be that it's adjusted so that it is out of the range of the oscillator ability to oscillate (too low).
Now I think I've got it!
(This post was last modified: 11-28-2016, 09:51 PM by Radioroslyn.)
Threads: 13
City: Rockville, MD
(11-28-2016, 09:22 PM)Radioroslyn Wrote: Hi Ed,
Ha Ha, yeah Terry you could say that. About a mile as the proverbial crow flies, near the Burgundy strip mall. Sadly WINX has gone the way of almost all the old AM rock stations. Now it's hispanic, and I can't remember what the call sign is. Only one tower now instead of the 3 or 4 that used to be off of 355 back in the day. It comes in loud and clear no matter what. Anyway, changed 6j8, no help, 140v on mixer, -6v at osc grid which drops to .113 or so at about 6 or 700kc. Adjusted padder c-6. Passes signal weakly at 600kc, but no stations. I think I'm gonna go cry in my beer now. Thanks for the response Terry. Really appreciate the help all you guys offer here. Ed
Threads: 270
You probably know this but I'll mention it in passing R-1 is listed as a 40M resistor. That = 40,000 or 40K ohms not 40 megohm. Check your ground connections at the coil. Rivets are always suspect.
Was down in ur hood for tday in Gsburg.
(This post was last modified: 11-28-2016, 11:41 PM by Radioroslyn.)
Threads: 13
City: Rockville, MD
(11-28-2016, 11:39 PM)Radioroslyn Wrote: You probably know this but I'll mention it in passing R-1 is listed as a 40M resistor. That = 40,000 or 40K ohms not 40 megohm. Check your ground connections at the coil. Rivets are always suspect.
Yeah, I replaced R1 with a new 39k I had. Was reading about 2500 over. Meant to mention that in the last post. Did you get to Rockville while you were down? How far is it from where you live? I'll check the grounds next time I'm poking around in there. Didn't think of that. Thanks for the heads up on that. Ed
Threads: 270
nah did quite down to Harvard on the Pike (a euphemism from my misspent youth)
Abt 3hrs north.
Threads: 13
City: Rockville, MD
Well, checking grounds around the coils and trimmers, they all seem good. Wonder if I could have a bum replacement tube in there. Still don't know why the grid leak voltage drops out when I turn the tuning cap to the low end of the dial. The oscillator can't be running with no bias can it? I also seem to remember reading that the 6j8 can be a finicky oscillator, but there doesn't seem to be any alternate replacement for it. The one in there is one I ordered as nos. Don't know where to go from here. Maybe try re-aligning it. Ed
Threads: 270
I like easy questions.
Because there isn't enough feedback to keep the osc running. This can be caused the tube not having enough gain (weak or voltages too low), Bad coil, or out of tolerance micas/ tuning cap shorted. Just for grins check the heater voltage on the 6J8 (needs to be 6.0vac or more).
The control grid needs or will be negative when it is oscillating. Not oscillating the grid will be at 0 or positive using a high Z meter, no VOM.
For a drop in replacement try a 12A8. None the the 6J8's 6v friends have a 150ma heater there all 300ma. Electrically the 6A8/12A8 has more gain than the 'J8 which is good.
(This post was last modified: 11-29-2016, 06:17 PM by Radioroslyn.)
Threads: 270
Sorry misread the specs, use 6A8. All the other tube have a 300ma heaters.
Threads: 13
City: Rockville, MD
Have to dig through my tubes to see if I have one. Meanwhile there is a cap on pin 4 of the 6u7 that doesn't look like it belongs there. Other end goes to ground. could this be a problem?
Threads: 270
(11-30-2016, 02:14 PM)leftwing25 Wrote: Have to dig through my tubes to see if I have one. Meanwhile there is a cap on pin 4 of the 6u7 that doesn't look like it belongs there. Other end goes to ground. could this be a problem?
Don't think so. Just bypasses the SG and SG of the 6J8.
Threads: 13
City: Rockville, MD
Ok, so tried another 6j8 I found, same results. Just noticed that I replaced R-8 with a .1mfd instead of the .22 I had intended to use. Would that affect anything badly?
Threads: 270
Methinks you mean C-8, possible maybe may alter the cathode voltage a bit. also check R-2.
Threads: 13
City: Rockville, MD
(11-30-2016, 09:46 PM)Radioroslyn Wrote: Methinks you mean C-8, possible maybe may alter the cathode voltage a bit. also check R-2.
Yeah, kinda thought that might be the case. Yep, c-8. Resistors don't use mfds. Also noticed B+ is about 14 volts low at the rectifier cathode, but plate voltages only about 5 volts low, i.e., 140 reading 135-138. Possible problem? Unfortunately don't have any 25z6's to replace it with. Anyway, will replace c-8 and see what happens. Thanks, Terry. Ed
Threads: 270
(12-01-2016, 06:45 PM)leftwing25 Wrote: (11-30-2016, 09:46 PM)Radioroslyn Wrote: Methinks you mean C-8, possible maybe may alter the cathode voltage a bit. also check R-2.
Doubt 5v is going to make much of a difference.
If you like excitement you tie a couple of 1N4007 across your 25Z6. Did I say that??? [Image: http://philcoradio.com/phorum/images/smi...on_eek.gif] That will get ur 140 up the abt 160. On second thought probably not a good idea. This set uses a voltage doubler where the DC output should be much higher than 140v. Typical doubler would have an output of abr 250vdc w/120ac input. Not quite sure how they get the power supply to work with such low output.
(This post was last modified: 12-01-2016, 07:15 PM by Radioroslyn.)
There are currently 1991 online users. [Complete List] » 4 Member(s) | 1987 Guest(s)
