Threads: 142
City: Lansdale
State, Province, Country: PA
I have a question about The Resistance readings on the following>>>
Power Transformer
Antenna Coil
Osc Coil
Output Transformer
IF Cans
My schematic has NO values for any of these..
Or does anyone have a different schematic with values on it...
Skip...
Threads: 270
>Power Transformer The highest resistance will across the HV winding(around 200-400ohms or so) next the 120v primary (10-30ohm) the the heater windings (just a few ohms)
Antenna Coil Pri pretty low 2-6ohms secondary pretty low also about the same.
Osc Coil Same as ant coil
Output Transformer primary 200-500 ohms secondary low a few ohms
IF Cans about 10-30ohms.
Mostly when you are checking the resistance of these items you are looking for a very high resistance indicating that the winding is open.
Generally with coils the lower the frequency the higher the resistance because it take more wire to make more inductance.
Now I think I've got it!
Threads: 142
City: Lansdale
Terry, OK great That makes perfect since..
See you on Sun..
Skip...
Threads: 142
City: Lansdale
Threads: 108
City: Calgary, AB, CA
http://www.adamsradio.com/page1.html
Here is where you can get the belt you need.
It looks like you have your work cut out on this one, but it should turn out good .
Dan in Calgary
Living in Calgary Alberta
Threads: 142
City: Lansdale
Ok, Update: The Transformer, Antenna Coil, Osc Coil and IF cans all have Continuity.. Nothing Open..
So now waiting on a Price ..
Can someone please tell me approx what to offer for this..I do not want to Low ball but also do not want to over pay...
This is from the ( Pickers house) That I had set aside. I liked the looks and cabinet wasn't Bad..
Help Please
Thanks
Skip...
Threads: 142
City: Lansdale
Threads: 59
City: Lexington, KY
(12-13-2016, 01:04 AM)vecher Wrote: ......So now waiting on a Price ..
Need to see a picture of the cabinet and how many of the Zenith wood knobs does it have?
The 6-S-229 has a photo finish so condition plays into the value:
http://www.radiophile.com/6s229.htm
Threads: 142
City: Lansdale
Ok, I will take picture.. It has 3 of the 4 Knobs Missing 1 knob..
Skip...
Skip
To be perfectly honest I never care about exact resistance reading of coils. If the coil is original and not open, it is OK and this is a fact. And you can tell open (infinite ohms)or leakage (hundreds of K to Megs to Gigs) from real resistance (units to tens of Ohms in RF coils, hundreds ohms in output xfmr primaries etc). And ohmmeter will not tell you about turn shorts.
So it is a waste of time to try to find out exact numbers. See if it is open. If not, it is presumed good. Rare cases of leakages and turn shorts are diagnosed by symptoms.
Threads: 142
City: Lansdale
Threads: 310
City: Kings Park NY
Hey,
The Photofinish looks good to me.. I would just clean up the cabinet personally.
If you want it better then strip the top only and refinish it...
DO NOT touch the photofinish...
Black magic marker will fix the trim issues...
I know you dont do cabinets (yet) but this is an easy one....
I think $75.00 max.. Probably $50.00...
Me
AC: 4 DC: 1
Easy for you to say. If I were shocked 60 times, I'd say the same.
Threads: 142
City: Lansdale
Have another question... How do you clean the dial? It seems to have spots .. I think when cleaning the pots some cleaner might have gotten on it.. I do not remember seeing them there before..
[Image: http://i292.photobucket.com/albums/mm38/...0nphbv.jpg]
Waiting on parts and belts .. Should be here this week .. Then start recap..
Thanks...
Skip
Find an inconspicuous spot, try mineral spirits.
If it works, you could do the rest.
There are currently 1568 online users. [Complete List] » 1 Member(s) | 1567 Guest(s)
