37-84 5y4 pin 1 to chassis
Nice 37-84 works fine after recapping/re-resistoring. Has a connection (apparently factory) from chassis to pin 1 of the 5Y4.
Disconnected for redoing the cap block it was hooked to. Left it disconnected and set seems to play fine.
Any idea why it was there?
Hello Rick,
The NEW metal tubes were introduced around 1936 and sets designed to use these tubes grounded pin 1 of the socket, which was connected to the metal shield around the tube. In situations where RF signals are present, such as the RF amplifier or converter or IF amplifier, leaving this pin ungrounded can cause the set to oscillate or poor reception. I had someone bring me a Zenith set once with this issue. It was designed for the G suffix tubes with a tube shield and someone had put a metal tube in as a replacement. I think it was a 6K7. By grounding pin 1, the set performed wonderfully. As the 5Y4 is a rectifier, it's not likely that leaving this pin ungrounded will cause many issues.
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1088 online users. [Complete List]
» 3 Member(s) | 1085 Guest(s)
