filament transformer
When restoring another brand radio, i found a Philco branded filament transformer used to step up 2.5 volt to 6.3 volt.
This radio was originally all 2.5v tubes, but someone had replaced  some with 6.3v types, hence the trannie.
Unfortunately, when i restored all tiubes to 2.v i didn't note how the trannie was connected.
So, can anyone tell me if this was an auto trans or?
It has 3 leads, is wound with heavy wire, laminations 5 cm  x 4 cm x 1.5 cm.
On the top, PHILCO
                  reg us pat off
                32  7019 M
If you restored it back to 2.5V why do you need the transformer anymore?
(12-26-2016, 10:42 PM)morzh Wrote:  If you restored it back to 2.5V why do you need the transformer anymore?
Good question, i want to use it to power a 1.5 v iJ5 tube which is the opt tube in a Zenith 6 J 230, a 6volt or 115 v ac set. all other tubes are 6 volt but the 1J5 has it's filament supplied via two special dial lights (blown) and resistors.
To avoid this i want to use the trans with a rewind and tappings to get 1.5 v.
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1005 online users. [Complete List]
» 3 Member(s) | 1002 Guest(s)
