Model 51-1330 Recap
Finished recap and tube checks. Replaced 35Z5 (open filament). Someone had been there before me and installed a couple of dual section capacitors on the power supply side which I removed along with the old wax types. Did note that C5 was missing. Replaced missing lamp.
Constant hum on power up. Also, noticed lamp get much brighter as tubes had time to warm. I added a C5 capacitor and no hum and good station reception resulted.
Planning to leave the C5, add 330 ohm across the lamp, and a polarized power cord.
I'm just getting started in restoration so comments appreciated. Thoughts on why the C5 was removed ? Anything on power cord connection point?
Hi Ariac     http://www.nostalgiaair.org/pagesbymodel...013711.pdf  I have posted a link to the Sch so others  may see what you are restoring. David
Hi and welcome to the Phorum,
Not really but set won't work well at all without it as it's ground return for the osc coil. With just the resistor there would think that would couple ac up to the b- circuit. C5 also provide a ground for the two IF cans which could pickup hum without it connected.
Neutral side of the line should go to the off/on switch on the set.
Thank you for the schematic link ! Holy cow, that 50l6 tube really gets hot !
Working on record player side now. Anyone know where I can find a tilt cartridge for the M22? I've been searching eBay and no luck.
I also have a 51-1330 but mine is still awaiting restoration. Tilt cartridges are virtually impossible to find. Most were crystal carts and went bad years ago. Apparently they did make a ceramic version but I've never been able to find one.
If you pull the radio, please post a picture of the radio circuit. Would like to compare. I have the radio working good. Yep, finding zilch on the web for cartridge replacement.
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
There are currently 1330 online users. [Complete List]
» 3 Member(s) | 1327 Guest(s)
