Threads: 64
City: Northbrook, IL
I think not only rectifier, but the whole tester is a big fat ersatz. Yet, I noticed that all big guys use TV-7, whatever brand it is, I 've bought some tubes with a sellers' stated good measurement on them and they all work fine, power tubes and otherwise. I also went through schematics of the mutual conductance testers, they have much more sophisticated layout, vacuum tubes, etc,whereas mine is as simple as they get.
Threads: 24
City: Edmonton AB CA
Without a doubt the TV-7 is a much better tester than your present tester but at a much higher cost. Be carefully buying one because they, just like yours, need to be properly restored and calibrated to provide the expected results.
Gregb
Threads: 18
The venerable Hickoks are also a good bet.
Threads: 531
City: Jackson, NJ
And hickok as a TV-7, only it measures not in uMhos but in its own units, which can be dealt with, just not as convenient.
Threads: 1
City: Rosemary, Alberta, canada
i have a Knight also and believe it's a 600 as there's no model number on it . i am told it works but i haven't tried it yet as i can't find a proper manual,calibration set up and tube lists . the ones i have come across aren't very good , like to find someone with a original manual and calibration,tube lists . the would send me a copy .
Threads: 336
City: lawrenceville nj
Threads: 1
Threads: 1
ok i got the manual, the parts list is blurry and hard to see , i want to replace all the resistors caps before i go any farther
anyone have a original copy that they can scan the parts list for me , it would really help me
thanks in advance
City: Lexington, KY
(02-09-2017, 04:33 PM)cantonkid Wrote: ok i got the manual, the parts list is blurry and hard to see , i want to replace all the resistors caps before i go any farther
thanks in advance
C-1 Capacitor, paper, .1 MFD, 400V
R-1 Resistor, l00K ohms, l/2 watt
R-2 Resistor, 270K ohms, 1/2 watt
R-3 Resistor, 51 ohms, 1/2 watt, 5%
R-4 Potentiometer, 200 ohms, wirewound, 2 watt .
R-5 Resistor, 470 ohms,1/2 watt,± 5%
R-6 Resistor, 1500 ohms, 1/2 watt, 5% ..
R-7 Resistor, wirewound, 2500 ohms, 7 watt
R-8 Resistor, 5100 ohm, 1/2 watt, 5%
R-9 Resistor, 1000 ohms, 1/2 watt, 5%
R-10 Control, calibration; 1200 ohms
R-11 Resistor, 68K ohms, 1/2 watt
R-12 Control, line adjust; 175 ohms, 25 watt
