48-472 No FM
Hi guys,
I've got one that I've been working on for a while. All caps replaced, tubes tested. AM works great-nothing on FM.
Any ideas?
Eric
The Villages, FL
If you input a 9.1 MHz FM signal from your 8601A into the first IF stage, do you hear anything?
Would that be applying the signal at the antenna or where it states in the instructions?
Eric
The Villages, FL
Where ever the alignment procedure says to input the 9.1 MHz IF signal for alignment should be fine. What you want to find out is if the IF or FM detector is the problem, or its the FM local oscillator that's causing no reception.
Great. Thanks. I'll check it later today and let you know.
Eric
The Villages, FL
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
There are currently 1372 online users. [Complete List]
» 3 Member(s) | 1369 Guest(s)
