Wirewound resistors
General question - why are wirewound resistors used instead of carbon? Can carbon of the same wattage be used in place of wirewound?
Don
Wirewound resistors are typically used in applications requiring higher power ratings than carbon resistors. The largest available carbon composition resistor is about 2 Watts, while wirewounds are rated up to several hundred Watts or more.
Wirewounds are also more stable and do not drift in value as much as carbon. If you want to replace a small wattage wirewound resistor, a metal oxide film or metal film resistor is a better choice as they are offered in a 5 Watt rating and are much more stable.
Old style carbon composition resistors of any wattage are practically obsolete today and are getting hard to find.
Hello again;   I found a model 838 car radio on Nostalgia Air under United American Bosch, http://www.nostalgiaair.org/...Arran — 09:32 PM
New Philco Repair Bench
Morzh is correct. The repair bench on our website is an archived image of chuck’s original site. He no longer provides s...klondike98 — 05:32 PM
Excellent information. It is all starting to come together now and your explanation really helped since I noticed that ...georgetownjohn — 04:39 PM
Hi John, I don't have this radio, but I can supply some info: Based on your pic, pins 7,8 and 1 are used together, go...MrFixr55 — 02:02 PM
As far as I know, the Repairbench does not work, and has not been working in a while. Chuck (we had that campaign looki...morzh — 01:33 PM
Radio city products 664 schematic request
Need a schematic or manual for the 664. The 663 may be similar.daveone23 — 12:38 PM
Thanks Gary.dconant — 12:16 PM
I tried accessing the site through our library and got the same response. It's reported to our tech gurus. GaryGarySP — 11:50 AM
