Speaker grill ribs
I have done cabinets where I decided to remove the ribs of the speaker gill on consoles where it was a simple as removing some screws and loosening small dabs of glue. They turned out pretty well and I didn't have to scrape out all the nooks and crannies when stripping. Whats the general consensus on doing that?
To each his own? or am I courting some sort of disaster when I do that? I have a 37-650 I'm planning on starting to strip tonight and am considering removing the speaker ribs/bars....
Test it on one bar, if you undo the screws and it doesn't come off with light finger pressure don't force it.
Yes, remove the bars and refinish separate.
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
>>when turning the knobs This is very broad. There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM
Bob; I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM
So I just purchased a Philco J1720 stereo and record player. That has some static when turning the knobs. Wanted to see ...PhilcoJ1720 — 12:26 AM
I've started looking into the very weak and garbled reception in the set (I have the HS-62A version of the chassis seen ...klondike98 — 12:00 AM
Those last photos were not very good,so I  used one of my other cameras. This is more like the true colors of the radio....Dan Walker — 10:48 PM
There are currently 870 online users. [Complete List]
» 2 Member(s) | 868 Guest(s)
