Speaker grill ribs
I have done cabinets where I decided to remove the ribs of the speaker gill on consoles where it was a simple as removing some screws and loosening small dabs of glue. They turned out pretty well and I didn't have to scrape out all the nooks and crannies when stripping. Whats the general consensus on doing that?
To each his own? or am I courting some sort of disaster when I do that? I have a 37-650 I'm planning on starting to strip tonight and am considering removing the speaker ribs/bars....
Test it on one bar, if you undo the screws and it doesn't come off with light finger pressure don't force it.
Yes, remove the bars and refinish separate.
Table radio 51C or 52C?
I think what you may have is another Phactory Phranken Philco, if the holes in the front panel lined up it was not unusu...Arran — 10:41 PM
Ho OSanders, Sorry, I got really busy in May and haven't seen your thread in a while.  I am VERY sorry about that.  ...MrFixr55 — 10:30 PM
Philco 45L Initial Check Up
Dan; I don't think that the model 45 is especially know for coil problems, not that they can't occur for one reason o...Arran — 10:19 PM
Yes, the end with the groove is positive, the stripe with the arrows points to the negative lead. The arrows have minus ...RodB — 09:36 PM
Thank you Rod and Paul I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it.  $5  Unable to fi...antiqueradionut — 05:14 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM
There are currently 387 online users. [Complete List]
» 2 Member(s) | 385 Guest(s)
