GE model L740
 [url=http://www.antiqueradios.com/forums/posting.php?mode=reply&f=1&sid=221e85fc9213ee38709336a60c8abbab&t=322909#][/url]
Is anyone familiar with a version of the GE L-740 table radio that features 9 tubes rather than the standard 7, including a 6AF6G eye tube and a horizontally mounted 6AE6G????
I acquired this radio many years ago, thought I had lost it to a closed repair shop, and just got it back. I subsequently bought another one last year and that one appears to be the standard 7 tube (no magic eye tube) model.
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
Mike, This is just a thought, the are on the coil where the verdigris (green oxidation is) I wonder if that is where ...Arran — 06:32 PM
Mike; I've made a one or two spiders by using some card stock, and a razor blade, it took more then one try but they ...Arran — 05:48 PM
Philco 91 Restore Code ??
I wondered about that. Wish there was some place local to get this stuff.dconant — 04:20 PM
Philco 89 indicator light.
Bending the lamp bracket (moving the lamp, that is) can possibly change the shape of the pointer a bit, but not its loca...morzh — 04:01 PM
Because the usable power rating of it then is (3,200/20,000)*25W= 4W. Maybe a tad more due to the mass, but not much. Yo...morzh — 03:59 PM
Thank you Dan, that was the trick. I kept trying to rebend the lamp bracket but that wasn't doing anything to help.Jim Dutridge — 02:18 PM
20K 25 watt. I thought it was a 20 watt at first.dconant — 01:37 PM
There are currently 4536 online users. [Complete List]
» 2 Member(s) | 4534 Guest(s)
