philco 42-360 power transformer
I have a Philco 42-360 that needs a new power transformer. The schematic shows 320 vdc on the output of the rectifier 84. I`m not sure what the current requirements are needed to operate this radio.
Welcome to the Phorum!
Icon_wave
Can't answer your question but someone surely will be able to help. The service bulletin for the radio is available at http://www.audiophool.com/Philco.html .
Hi and welcome to the Phorum,
Your looking at about 60ma. They're pushing that 84 pretty hard.
Well....let's try to do the first order calculation.
The rectified voltage is 320V. The dropout across the field coil's DC resistance of 1.7kOhm is 130V (down to 190V). We're lucky we have the numbers directly before and after.
This makes the total of 130V/1700 Ohm = 75mA.
Now each half-winding will conduct the same average current exactly 1/2 of the period that makes it 38mA average per half-winding.
Add a margin of say 50% (or whatever you are comfy with), this will make it 57mA. I'd say, that is enough.
(Almost radio engineer)
PS. Saw Terry's reply. Hey! I was pretty darn close! Icon_lol
Hey Mike,
I do the rough calculation by multiplying the # of tube not counting the OP or rectifier X 5 (ma) If and tube has more than 1 section + 5 more ma per, diodes don't count. OP= 20ma. So 7 tubes X 5ma + 20= 55ma + a little for good luck=60ma.
Then I look up the tube specs to see if the rectifier can handle the current load. 84 is good for 60ma.
I'd do the same, but when I'm lucky to have the Voltages directly shown along the current path, with known resistances for the dropouts, I use those - takes the guesswork out of the process.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
