Threads: 85
City: Cumming, GA
I've been working on this one for a while and I have the same problem and that is identifying grids on tubes.
http://www.nostalgiaair.org/pagesbymodel...012465.pdf
In the procedure calls for connecting to the Converter grid through a .05 cap to the signal gen? Now the paperwork lists the 12BE6 as the OSC Converter
Pin #1 Ocs grid, or 6,7. ???
Does it matter the position the tuner is paper work does not say?
Thanks Eric
Pin 7, I think.
Dial should be set at some lower frequency, like 560-580kc.
Threads: 85
City: Cumming, GA
This thing is making me crazy
It appears I have an intermittent problem.
1-FM works and has from day one.
2-The AM will come on play for a while then fade out.
3- I have checked and replaced all resistor out of Tolerance
4- Tubes have been checked and I have had put replacements in no change
5- I have done voltage checks and do not see anything crazy I'm using a digital meter
6- it is not working more than it is, I've poked and prodded looking for cold solder Joints
7- Had no problem doing an alignment on the am side tone was where it was supposed to be.
I'm beginning to think I might have a capacitor going bad, there are a lot of small dog bone PF capacitors?
Any idea's on where to look??
Thanks Eric
Threads: 270
When it fades out do the tubes stay lit??
Could have an intermittent filament or bad connection at the socket.
Use a second receiver to listen for the local osc @ 455kc above the broken set's dial setting when it's faded out.
This will rule out an intermittent osc coil.
You can use your signal generator to troubleshoot by ejecting a 455kc signal at the ant when faded.
This will tell you if the IF,det,and audio are the issue.
Now I think I've got it!
(This post was last modified: 07-22-2017, 01:44 PM by
Radioroslyn.)
