Emerson 350 aw
#76
Making some more progress.  I’m going to replace the grill cloth with Kenneth Richmond’s large herringbone cloth because there was a hole in the original but I wanted to use the piece to try cleaning it as an experiment.  I tried Resolve, the carpet cleaner.  You spray it on, wait 5 minutes, and then using a damp cloth you dab at the grill cloth soaking up the dir.  It did pick up some of the dirt and transfer it onto the damp cloth and it might have come cleaner with a second round of cleaning.  I almost could have used the existing grill cloth but there were some areas, where it was most exposed and dirtiest, where the cloth had rotted to the extent it fell apart when dabbed with the cleaning cloth.  Still, it may be useful in the future.
Before spraying on the Resolve
[Image: https://www.dropbox.com/s/w691tcfjagoymb....jpg?raw=1]
After the spraying
[Image: https://www.dropbox.com/s/rg6qtn8rej2wcj....jpg?raw=1]
After dabbing with a damp cloth and allowing the grill cloth to dry
[Image: https://www.dropbox.com/s/hnmaexarzj1q3h....jpg?raw=1]
As I was working with the door I realized that there was a missing piece on the back of the cabinet, almost a quarter round piece of trim.  I found a walnut square dowel of the right dimension and just had to router the edge.
[Image: https://www.dropbox.com/s/t0rugoetfkt7a5....jpg?raw=1]
[Image: https://www.dropbox.com/s/xz6eiqqx75n04i....jpg?raw=1]
Also got some toning done.  After toning I reattached the reproduction door to the cabinet using the same method the previous restorer had used, i.e. a couple of small brads with the head cut off that fit into two holes on the hinge dowel and two holes I drilled into the door.  A little glue was used to fasten the brads to the wood.  At this point I only have the first few coats of clear on.  The top has very a small grain that I hope to fill with the lacquer after a few more rounds of coating and sanding.  Then I'll rub it out and put it all back together.
[Image: https://www.dropbox.com/s/zhsgfhizpfe8hi....jpg?raw=1]
[Image: https://www.dropbox.com/s/655fat57xazgqr....jpg?raw=1]
#77
Looking good. Icon_thumbup  Good catch on the trim piece. I've tried the Resolve cleaner on a couple old grill cloths and didn't have much luck. They tend to start crumbling with any rubbing.
#78
Yes, every time I've tried to recover a vintage grill cloth by cleaning it in some way, it has not been a good experience. They are often too fragile.
#79
This puppy is done...(well, except that I realized the knobs are not right...but compared to the door replacement and the IF coil surgery that's just something to keep an eye out for at the next KTown.)
I had the chassis back into the cabinet, knobs on, back on and....it would not play...
Then I remembered way back in the beginning one of the wirewound resistors in the filament string circuit was open and I'd aligatored a temp in place during the electronic restoration but never made it permanent.   Icon_rolleyes
Took it back apart and added that resistor and all is well.  Icon_smile
[Image: https://www.dropbox.com/s/fs831eyj9fwkcs....jpg?raw=1]
[Image: https://www.dropbox.com/s/36vd2re8e0fr26....jpg?raw=1]
#80
You did an excellent job! Icon_thumbup Icon_thumbup  I really like it.
#81
I am amazed my friend...
That door is beautiful...
Great job!
Icon_smile
Thanks guys!
#84
BY GOD,,,that is Beautiful ,,,,,Mint condition,,,,right out of the BOX,,,,,CHEERS
#85
Looks snappy, Bob!
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
Philco 42-390, code 121 speaker
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A...captainclock1988 — 03:43 PM
Using a 5W  1.5k  ceramic resistor in place of the field coil and using a 4 ohm PM speaker, I was able to bring the radi...Stevelog — 02:57 PM
Philco 60 Squealing
I have taken out the 2nd IF and found a problem or not. I believe the coils are litz wire. There is a very small strand ...dconant — 02:13 PM
Philco 6K7
I am restoring a Philco 37-60. The am reception is very good, but the shortwave is very weak. Run 6 Philco removes the g...bobbyd1200 — 01:35 PM
There are currently 4153 online users. [Complete List]
» 1 Member(s) | 4152 Guest(s)
