Philco 20 base toner color
I'm looking for suggestions for the appropriate Mohawk toner lacquer color for the base of a Philco model 20. Also wondering about the correct cabinet tone, should I decide to venture that far,
Mike
I'm interested in this too. Sooo, following
- Eric
Philco 20A
Zenith T825
There seems to have been quite a bit of variation in the finish of the Philco 20 cabinets. Some 20 cabinets were toned pretty much the same color over all, including the base, while others had dark shading around the edges. Many of the cabinets that had the edges shaded, had the dark shading on the base also. Since I don't use aerosol toners, I will leave that for others to answer. Ron?
Eric (MrGrnEgz), I noticed that the base on your cabinet is a little rough. I think Ron has a set that he would like to sell.
M R Radios   C M Tubes
(08-14-2017, 12:08 AM)Steve Davis Wrote:  Eric (MrGrnEgz), I noticed that the base on your cabinet is a little rough. I think Ron has a set that he would like to sell.
I'd like to talk to Ron. TBH, I'm not sure who Ron is quite yet, but please let him know I'd like him to PM me.
Thanks Icon_smile
- Eric
Philco 20A
Zenith T825
After searching around the phorum some more I now see who Ron is... Icon_smile
- Eric
Philco 20A
Zenith T825
Yep, Ron Ramirez, the Phorum Administrator aka Mr. Philco.
I am indeed Ron, and will answer your PM shortly.
So, what have you decided to use? Is it possible for you to post a picture or two? Thanks!
Table radio 51C or 52C?
I think what you may have is another Phactory Phranken Philco, if the holes in the front panel lined up it was not unusu...Arran — 10:41 PM
Ho OSanders, Sorry, I got really busy in May and haven't seen your thread in a while.  I am VERY sorry about that.  ...MrFixr55 — 10:30 PM
Philco 45L Initial Check Up
Dan; I don't think that the model 45 is especially know for coil problems, not that they can't occur for one reason o...Arran — 10:19 PM
Yes, the end with the groove is positive, the stripe with the arrows points to the negative lead. The arrows have minus ...RodB — 09:36 PM
Thank you Rod and Paul I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it.  $5  Unable to fi...antiqueradionut — 05:14 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM
There are currently 395 online users. [Complete List]
» 2 Member(s) | 393 Guest(s)
