New chassis washers for a Philco 89
OK people, how the H**l do you get the chassis reinstalled in the cabinet with new washers? I've tried tilting the chassis towards the front but the replacement washers just seem to be too D**n high. I got these from Renovated Radios and these are suppose to be for chassis made between 1932 and 39 or something close to that time period.
I seem to remember on mine I squared off two sides of the chassis spacers on the disc sander to get them to fit under the corner lip of the chassis. That's about 4 or 5 years ago now but as I recall the tabs under the chassis where the screws go into are a bit recessed and not flush with the bottom edges of the chassis. It's probably not the right way but it worked for me. Icon_thumbup
I did not fix 89.
But.
How about a dab of some glue to hold them in place while chassis is being pushed in?
Stupid me, I ordered the wrong size for this radio. I took a guess at the correct size since mine didn't have any. I have since ordered the smaller height ones.
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
Philco 40-120C Restoration
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
Have you tried a different speaker? How did you trace the distortion? How do you know it is weak? What is the reference?...morzh — 08:33 PM
Amen to that! Every time I think I’ve captured them all, I realize that there’s another error. My goal is to finish with...jrblasde — 07:00 PM
