Micamold Capacitor Value and Type ???
Can one of the knowledgeable members help me identify the type and value of a Micamold cap? Illustration of the cap follows. This item is from a Philco 41-290, first IF can (item 32 – p/n 32-3482). Cap is about 3/4" x 3/4" in size.
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Ok I'll take a stab at it. The top red dot = 2 (20%) Bottom dots = 300. 300pf@ 20%. If it's on the plate side of the coil go with a 500v job ( common).
Good Luck
Thanks for your reply. If the bottom dots are the cap value, I think it should be 30 X 100 = 3000pf.
First digit (orange) =3, second digit (black) = 0, and multiplier (red) = 2 or 100. At 3000 pf, it is unclear to me if this is a encapsulated paper cap or a mica.
Any thoughts will be appreciated as the schematic does not detail the value or type for this cap.
Thanks
According to this website, TFB, you are correct.
But I wonder about 3000 pF in that circuit?
Very interesting. The primary of that IF transformer is slug tuned, as are many 1940-42 Philco IFs, and it uses that mica cap in parallel with the primary winding.
Being a Micamold cap, it's hard to say if it really is mica or not. Some Micamold caps have a paper cap encapsulated in that package that looks like a mica cap. The Micamolds are beginning to fail at a rising rate, also.
I would replace it with a new mica cap or an NP0 ceramic to avoid drift while in operation.
Don't know but .003 seems a bit large.
I just happened to look at a schematic for a 41-295 (fairly similar unit) and it details this cap at 3000pf. I also thought this was somewhat large and was the reason I posted the inquiry. At 3000pf (.003mf), it's likely to be paper and I'll replace it while I have the IF can disassembled.
Thanks to all for you assistance.
Good catch, TFB. Thank you for enlightening us.
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A5...MrFixr55 — 06:48 AM
I think it would come under either American Bosch or United American Bosch. American Bosch made sets for the American We...Arran — 05:53 AM
Gilfillan Brothers Car Radio?
There are currently 5944 online users. [Complete List]
» 2 Member(s) | 5942 Guest(s)
