philco 490 speaker
ok I am working on a philco 490 dose any one have a photo of a k-3,k-4 or a k-25 speaker
Benny
Hi Benny,
[Image: http://www.antique-radios.net/radpix/phi...clcksp.jpg][Image: https://thumbs.worthpoint.com/zoom/image...ce1b5a.jpg][Image: http://i1211.photobucket.com/albums/cc43...ch/_12.jpg]
Sometimes called a pie pan speaker they were used on the models 20,21, 70, and 90. The speaker seems to be all the same in terms of specs but the output transformers are different, some are for p/p output and others for single end output. One from a later version of the 90 or a model 70 should be fine for your application.
thank you Terry for the photos I have a speaker like this. it seams to me that the wires from the speaker to the chassis should be a bit longer
benny
Perhaps your spkr came from a baby grand (table top) set rather than a console. The important issues are the output transformer, does it have 4 or 5 wires ? If it has 5 wires it would be for a push/pull output stage which wouldn't give you a good impedance match for your single 47. You want to see 4 wires.
And the other is is the field coil good? If not then you will need to rewind it or find a spkr w/a good one.
Lead length isn't much of a problem, at 80+yrs old it would hurt to replace them anyway.
single 47, 3 wires what's the best way to rewire the speaker portion of the speaker do you think I am careful I could remove the cone to unsolder the old wires
benny
Typically rewiring the spkr wouldn't require unsoldering the voice coil just replacement of the wires connected to the primary of the opt and field coil. If you need to remove the cone/vc then you would need to unsolder the voice coil. It's soldered to the secondary of the opt and has a little spring contraption that holds the wires in place. It pinches them so you can pry them out gently. Remove the screws along the perimeter of the cone and the one in the center and the cone can be removed.
I forgot to make mention of it the other day, but last week I corrected another error on my schematic (applies to both R...jrblasde — 09:27 PM
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
There are currently 1888 online users. [Complete List]
» 2 Member(s) | 1886 Guest(s)
