Push Button Tuning on 41-629
I have restored a 41-629 (Yes, it is a BOL) and have the radio working after many hours of replacing all of the wiring and repairing the primary of the output transformer (3 opens). I would like to set the push button tuning but I am not sure of the proper procedure. There are only 5 PB's on this model, and on the back of the radio are ten holes for adjusting them. They are numbered 10 to 1 sarting at the left side facing the back of the chassis. I believe 2 are dedicated for each PB with 1 for oscillator and the other antenna (?) I have tried aligning them with a sig gen with loop antenna next to the radio loop but can't seem to get the stations correctly, or with poor volume compared to regular broadcast tuning. Does anyone know if there is specific tuning "range" for each PB, and what they might be?
As far as the BOL tone arm I am still working on this. I have replace the voltage cell with a dollar bill one and most of the rubber isolation mounts. I need to address the needle assembly rubber yet.
marv
I don't know it off hand, but I know the pushbutton alignment procedure is in the original Philco Service Bulletin.
Ridres many times omitts a lot of original info.
There are different freq ranges for various models - not all the same, depending on the number of buttons, etc.
Chuck
Where would I find the correct service bulletin? Thanks.
Here is the page from the 1941 Philco service manual on how to set the pushbuttons:
1941_Philco_Pushbutton_Setting.pdf
Sean
WØKPX
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
There are currently 2117 online users. [Complete List]
» 2 Member(s) | 2115 Guest(s)
