116X plummeting B voltage
Hello,
Foolishly, I was attempting to align this radio with a screwdriver and shorted something in the process. I was very close to finishing and now, there is no sound, the wirewound resistor(part96), transformer (part 92), and one of the 6A3s all get very warm almost hot to touch. When I power up the radio, I observe the B voltage at the input filter(part103) climb to about 280vdc then there is a pop in the speaker and the voltage drops in a hurry to about 150vdc and things start to get warm.The power transformer seems to be ok. Live and learn, as I should have known better. Where should I look to troubleshoot this problem, please point me in the right direction. Thanks, in advance.
Marc
Check for negative voltage on the grids of the 6A3's. Should be about -60v. If you don't have it on both grids Check the center tap of the driver transformer (92) If you got it there replace 92. Check for plate voltage on the # 42 tube. If is is low replace (92) Also try removing the #42 and watch the b+ to see if it drops as the set warms up.
Thanks. I really appreciate this information. Through no effort on my part, the B voltage has resumed normal values...so the problem may actually an intermittent one. I will follow through. Marc.
Glad to hear it seems to be OK. You may want to put a small fuse in the CT of the HV winding of the power transformer. Just to be safe. Should be a great sounding set! I've got the 37-116.
I edited the topic title to avoid confusion. There is no such thing as a 36-116X. The correct model number is 116X.
Intermittent problems can be the toughest ones to solve. Terry's given you some excellent advice, Marc; best of luck with your set.
Philco Model 249 made in England
Gary - Thanks for responding!  I hadn't actually taken possession of it at the time of my post but since you said it was...fklown — 03:32 PM
Philco model 40-100
Marion; Replacing volume controls was something some service shops did in years gone by to make a little extra profit...Arran — 03:24 PM
Welcome to the Phorum, fklown!  That's one heck of a Philco 'yardstick' you've got there!  Could you possibly post a clo...GarySP — 03:19 PM
Philco model 40-100
Arran, Thank you so much for your assistance and the link to the fleabay listing! They say a picture is worth a thousan...mhamby — 01:43 PM
I wonder if anyone has any information or experience with this model.  My internet searches are coming up with nothing. ...fklown — 11:40 AM
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
There are currently 678 online users. [Complete List]
» 2 Member(s) | 676 Guest(s)
