Philco 90 toner and grille cloth
Hi,
I'm restoring a Model 90, and using Mohawk toners. Most restorations seem to make the pillers and feet a darker color than the body, I'm using Perfect Brown and Dark Walnut. Can I spray the entire cabinet Perfect Brown and after drying put the Dark Walnut over it?  I know that the Walnut will probably melt the Brown some but will the Walnut lay on top of the Brown OK?
Also, until a couple of years ago you could get good replacement grille cloth even the original copper color, but now there seems to be nothing close. Anybody know of any source?
Alan
Your best bet would be to try the various toners on pieces of scrap and see how they look. that will let you get it to a tone that you like.
Alan
Yes, it is perfectly fine to spray your main body color overall, then spray just the areas needing to be darker with the darker toner, provided you carefully mask off as needed using newspaper and green Frog Tape.
Whatever you do, do not use blue painter's tape. I learned this the hard way a few years ago...it is chronicled here in the Phorum somewhere...
As for cloth, you have two choices: Whiskey Rayon from Kenny Richmond, or GRC02 from Radio Daze.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
