Crosley 577
All, I just picked up a Crosley 577 radio from Antique store in Kutztown.. Paid 10.00
But my luck it uses a Resistive cord again.. So need to know what resistor and or cap to use .. Here is schematic I drew up for Filament string..
[Image: https://farm5.staticflickr.com/4485/3689...260f_b.jpg]
PS here is a picture of front..I like the dial..
[Image: https://farm5.staticflickr.com/4501/3689...1dc3_b.jpg]
Thanks
Skip...
If you use a diode and resistor =33ohms @ abt 10w (actual dissipation abt 3w)
Just a resistor 150 ohms @ 20w or better.
Nice little set Skip, small is good for space considerations.
Good luck.
That's the first time that I've seen an AC/DC radio actually proclaiming that it was "AC-DC" on the front, right on the dial yet!
You can use a diode to drop the line voltage. Use a 1N4004 and place a zener diode of the correct voltage across the dial lamp. Forget about trying to use a resistor. You will not find one that will disparate the heat that will not damage the cabinet. I have replaced several resistance line cords this way. Just make sure you install the diode and zener with the correct polarity.
I just dug one of these out to work on. Mine is the same only does not say "Fiver" or "AC DC".
Chassis in great shape cabinet needs ALL new veneer, but it won't be hard.
These seem to be rare with round mirror dial. In the "Super" series yet it does not say Super 5.
Bill already did a nice job getting 70 volts.
Ah, another "curtain burner."
On the Phorum is a video from a NEVEC member on the correction for these sites, now if I can find it....
Mine is the "early" version. I'll probably veneer the cabinet tomorrow. Also the diode - resistor dropper that Bill had already installed is neat and almost unnoticeable. I'll try and get pics. I was looking for a picture of the cabinet top. Veneer is gone on mine and the top was painted brown. Also damage to the front/sides veneer. So I'll just do it all.
A cap, unless you want to keep it AC/DC.
Most times it is 6.8uF.
Calc it if needed.
37-690 Bass Choke Replacement
Yeah, I know, Mouser and Digikey don't have "big iron" components. For some reason Philco was messing with the...Radiodial — 04:25 PM
Yes, I just had to deal with that while repairing the 37-604 Philco. Exactly that value choke was gone. And the current ...morzh — 03:52 PM
Ah, now where to find one. I've into this before on smaller sets, I now recall. Hammond makes one that is only rated...Radiodial — 03:27 PM
Philco 38-7 Speaker
Ask the admins to put them together. As for the renaming, while inside the thread, you simply press "New reply&quo...morzh — 02:23 PM
This is the parts catalog. 32-7528 choke is 65H, 10mA, 2,250 Ohm inductance. Find a suitable one.morzh — 02:18 PM
While troubleshooting the no bass amplification issue, I think I found the culprit. The choke #104 is reading 164K ohms....Radiodial — 01:42 PM
Philco 60 Squealing
Your IF transformers are tuned to the resonant frequency they were designed for. When you observe the bell curve they di...RodB — 01:35 PM
identify very thin wire for replacement on 37-640
Thanks so much for your help!  I really could not have gotten this far without the kindness of you and other members.  T...georgetownjohn — 11:50 AM
Philco 38-7 Oscillation
Will do, thank you.tludka — 10:26 AM
As to your oscillation issue I would align the IF transformers. That may solve the problem. You also would want to check...Radioroslyn — 10:22 AM
There are currently 3000 online users. [Complete List]
» 3 Member(s) | 2997 Guest(s)
