40-216 How would you handle this?
This cabinet isn't perfect but it is in good enough shape I want to try and keep it original.
I know after seeing this you may be like "NO WAY THAT IS TRASHED" however I didn't even see this spot, and the other two that are not as bad, until I got it home. Even then they are hard to see.
So I have some ideas on what to do but I'd like to see what your thoughts are about this situation.
My main goal would be to do something so that the edges poking out are at least taken care of so that when I clean it down with a cloth nothing snags.
So here is what I have...
[Image: https://i.imgur.com/DCR7LGH.jpg]
http://philcoradio.com/phorum/showthread.php?tid=16602
Strap clamp was one of the thoughts I had Icon_smile
Thanks. I'll look this over.
You can try all sorts of things. It is very likely that none of them will be permanent.
You have 2 layers of broken veneer and poor adhesion. Differences in humidity and temperature are likely to open this radius split again over time.Replacement of the veneers and inspection/repair of the underlying structure are the only long term fix.
I second what Russ said, I've tried the short cuts, they look good for maybe a year or more and then you are right back where you started.
(10-14-2017, 12:21 PM)Phlogiston Wrote:  You can try all sorts of things. It is very likely that none of them will be permanent.
(10-15-2017, 02:27 AM)Arran Wrote:  I second what Russ said, I've tried the short cuts, they look good for maybe a year or more and then you are right back where you started.
I agree. The best and maybe the only permanent repair to to remove the existing veneer, clean up and repair the structure underneath it and re-veneer. To get the columns to match (L&R) you will probably have to do both.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
